ankitbhargava
Hi everyone
Last 3 weeks my AVR while in usage goes in protection mode (orange light blinks), it has happened 3 times randomly in last 3 weeks.
There is a "dhupp" sound from speakers and the AVR goes in protection.
Restarting after few seconds it works well again
So far to troubleshoot, I have cleaned it up properly using soft brush and mild blower.
I have also checked speaker wire connection for any lose connection of shorting. My speakers terminate into AVR (rear surrounds and 4 X Atmos) using proper Banan Plugs. The other speakers on Emotiva Amp also terminates using Banana Plugs.
I couldn't find any problem.
I use Infinity Fans to keep the AVR cool and also take care of moisture if any, though my Room is not dedicated and has some ventilation. While using HT setup, generally my AC is on.
What could be potential reason for this problem?
Just to mention, when I touch the banana plugs or HDMI cable's head on AVR, I do get a very mild shock. However this has been there for years now.
