My first post
sanjay chatterjee
PATNA
HELLO TO EVERYONE I WOULD LIKE TO KNOW UR SUGGESTION THAT FOR HOME THEATRE WHICH RECEIVER SHOULD I PURCHASE MY BUDGET IS 200000 including receiver two towers and subwoffer as i have already Panasonic blue ray player in my house .My room size is 750 sq feet.plz let me know i have only heard denon 2313.
750 sq feet...you need real powerfull machines..
I suggest consider a amp also which you can connect from avr front pre outs....
so consider avrs with pre outs...2313 is with pre outs??
Just to make sure that there are no typos in your post would you confirm that your room size is 750 square feet and budget 2 lacs for AVR, front towers and Subwoofer?
Welcome to HFV with that Whopper of a Budget and that sized rooom!! waiting to see what suggestions keep getting posted here :) ..
Of the top of my head..since you want a receiver I would suggest a Yamaha Aventage series may be an Ax- 820 or a 1020. The preferred Denons I ve heard are 2312, 1912 and I would prefer a 2312 over the Yamaha 810 and 1010 but not more than my Ax 2000...
But as many have suggested me and tried to mend my faults.. firstly try listening to the speakers and start pairing with a suitable AVR...
ergo. Speakers: where I really think you should listen to some and decide.. depends.. because some people prefer warm sound and some prefer neutral while very few would prefer anything leaning towards a brighter side...
Warfedales , Dali Ikons , Monitor Audio, B&Ws, klipschs, are some brand that I can suggest after listening to them you can start narrowing your searches with less ambiguity :)
All the Best for your Auditioning.. take your time..and listen over and over again if in doubt
