Looks great.. very well planned.[emoji122]
need details of your ht.
1.room size
2.screen size,projector used.
3.room acoustics.
4.avr model number.
need the above as i am into building one.
thanks
r/s.
The size of my HTR is 17ft * 10.5ft. Screen is custom made . Its designed for wide screen movies since I like cinema scope movies. its 10 ft length and 4.75 ft width. Projector I am using is Epson 2030 from U.S. Room Acoustics is also DIY type. I got a lot of information from various HT forums. On the wall fixed aluminum channels and then Rock wool sheets to reduce the reflections. after all I covered with a material called Spun which is using for making Bags etc. Now no echo. and almost sound proof. Denon X1200 and polk speakers used inside. Sub Polk DSW550.
Won't a 16x9 native projector show wider aspect movies with bars at the top and bottom? So a wider screen will be better for such movies. Only 16x9 movies will need be projected with bars at the sides.2030 is widescreen natively .. and you using cinemascope .... both dont go together unless you using Anamorphic lense ... which I dont think you using.
The beginning stages were nicely captured. I wish you had shown more of completed visuals too - please make another video of the completed setup.
That Dolby Atmos sign - very nice
Check with computer experts if it can be accessed. You might get lucky [emoji4]I captured each and every moment of the work. Unfortunately the memory card was kept in my wallet for 2-3 days and got damaged.
