Ravindra Desai
Hello all,
I am listing a few of my success stories with pictures.
I hope that you all will benefit from it
Glasswool panels covered with porous jute cloth was used in all cases. MDF board panels were used to hold the glass wool.
I will always be using this no matter what. What changes from case to case is the application (speech, stereo listening, movie watching) and the ratio of absorbing area to reflecting area.
Attached are pictures of some work/ cases that I did:
1. Heera Shri Residency Club House, Kolhapur, Maharashtra: There was so much echo that the builder was not in a mood to set the ribbon cutting dates. The opening ceremony was to be carried out in the club house of this posh gated community. He wanted good looks too.
I did the panel work calculations and worked with the builders architect for aesthetics. Used white Ahuja speakers to hide them in the colour scheme and powered it with my ampli processor (40Wrms with LMT). Problem was solved to the satisfaction level of the builder. ref photos 1-4
2. Keshav Smriti Hall, Chikkodi, Karnataka: After spending 4 crores to build the hall and another few lacs for the ceiling (which did not help the acoustics), the hal simply was unable to attract any clients for functions.
I worked on whatever limited space that was available, used heavy treatment with big NRC, and using a simple design solved the acoustics. So much so that the board prresident called me after they successfully conducted a classical music program where Shridhar Phadke was the guest singer.
Used Ahuja 4 x 15" full range speakers near the stage and angled them so that they covered the area correctly. Two on each side of the hall. Powered them with my ampli-processor 40Wrms for lower speakers and 80Wrms for the higher speakers. ref. photos 5-7
3. Niks Bass, Ichalkaranji, Maharashtra: The owner has a small time audio shop. His rented space was booming and he was in a jam as the rent was already catching up on him. I used the open wall spaces. Kept the design simple of the purpose of cost. Booming was gone and he was happy that he could now conduct demos nicely. I did not supply any sound system in this case. ref photos 8-9
I hope that you like this.
Ravindra.
Ravindra.
