Can you check if the pulley isn't slipping on the motor shaft? This can cause play back speed issues, though if it is steady at even the lower speed, the pulley isn't the fault. Sometimes the pulley can unglue itself from the motor shaft causing it to slip. You need to remove the belt and turn the pulley by hand and feel for variation in feel while turning the motor shaft.
