Need a 26"LED to use as both TV and Monitor
icemanz
Cochin
Hi All,
I need to replace my old CRTV in bedroom with a 26" or 32" LED TV which can be used both as TV and to connect my PC.
Budget is about 27K. HD ready models will be fine and need audio in on tv for pc sound output.
Please suggest good models.
Anybody has experience with AOC TV's? I've heard their monitors are good.
AOC LED TV model -LE32A3520 is available for about 24K with 3 years waranty. Only 1st year is comprehensive thou, 2nd year is labour free.
It has both VGA and PC audio in. The picture quality was at par with the sharp and Philips LED TV in the showroom.
Thanks Frost, I did check out the Samsung 26EH4000. It looks sleek; however lacks the pc audio in. Looks like I will have get a 2.1 audio system with the team for decent audio. Most of the 24" and 26" TV's have pretty feeble volume.
Philips 32PFL4556 LED TV 32 inch for 23,990 at reliance digital, is it worth? Please suggest, need to buy in next two days. Reliance says the prices may change.
I am using 32" Eh5000 samsung LED as monitor so if you can increase your budget a bit. Go for 32"EH5000 ^^
Full HD is better for monitor.
