sameerevelyn
I have only tower speakers JAMO S626 and the specification as below: and i need to change over my old Onkyo amplifier to Yamaha R-S202BL Stereo Receiver see the specification right below speaker and since its comes with Bluetooth want to go for it . Could you please anyone suggest or advice if it is worth it to buy mention YAMAHA Amp. Can i connect this amp to my TV as well . sorry for being dump
JAMO S626 specification
System Type 3 Way Bass Reflex
Impedance 6
Tweeter (mm/in) 25 / 1
Woofer (mm/in) 203 / 8
Frequency Response (Hz, +/-3dB) 42-20,000
Power Handling (Watts Long/Short Term) 130 / 210
Sensitivity (dB, 2.8V/1m) 89
Midrange (mm/in) Dual 127 / 5
Crossover Frequency 150 / 2500
section
Bluetooth
Specifications
Maximum Power (4 ohms, 1kHz, 0.7% THD, for Europe) 115 W + 115 W
Maximum Power(8 ohms, 1 kHz, 10% THD) 140 W + 140 W
High Dynamic Power/Channel (8/6/4/2 ohms) 125 W / 150 W / 165 W / 180
Frequency Response 10 Hz - 100 kHz (0 0.5 dB / 0 3.0 dB)
Impedance 6
section
Bluetooth
Specifications
