Need a good VR for OnePlusTwo
urindian
Chennai
Dear all
I'm inclined to buy a VR for my OneOlusTwo within 10k.please suggest a good one based upon your experience.
J
I just checked and Google Cardboard or its variants are available on the likes of Amazon India. Not too sure about the quality, but it's DIY and works very well.
Samsung will be in budget, however not too sure how it will work with other manufacturers.
Samsung Gear VR - The Official Samsung Galaxy Site
I have played around with it on a Samsung Galaxy, works very well. Content though is somewhat limited.
Gear VR only works with S6/S7/Note5. It will not work with 3rd party devices.
None of the cardboard devices are as good as the gearvr as the latter has dedicated sensors and a low latency render path.
samsung gear VR works with only samsung devices
Dear all
J
Hi I have THIS.... but its not a professional high quality VR, in the lines of oculus, or Vive or gearVR for that matter, but still is good enough to let you venture in to the world of VR and 3D SBS movies ..... I enjoy it for 3D movies more than VR apps .... I use it with HTC One M7 and occasionally with Nexus 6p
How do you control your phone when it's inside HMD?
Sent from my Nexus 5 using Tapatalk
The unit also comes with a Mini Bluetooth Remote Controller, check the link .... however I must say that its very cheap and does not work the way it should gives you just very basic control and i am not very happy with it .... a professional VR has a different way to get this done ...
