Need a home theatre system within 25k inr
Kingshu
India
Ok I am new at the site. I am not an audiophile. Recently I got a new 40 inch sony Bravia TV . It's visually stunning. I am using it for my Bluray and video games. My main media source is my PC. But my old creative sound system (t6300 5.1 channel) not upto the mark. I have never a good relationship with these 5.1 speaker systems. I used budget oriented 5.1 speaker from creative and philips. But none of them are good. Either their is no bass or bass is so heavy that I cannot hear audio clearly. So this time I just want a good sound system
So I choose four of them
1. Logitech z906
2. Yamaha yht 196
3. Onkyo HT 3400 (although it exceeds my budget slightly)
4. Sony HT IV 300
I played lots of video games so I need good bass for any action sequence(explosion, car sound) but I want to use it for my movies so I need cristal clear sound. And lastly sometime I want to use it for my music. I mostly listen indian classical so I need good mid and treble.
As I already said I just want to use it with my pc so I need easy connectivity.
So please suggest me which one will be ideal for me
Depending on which city / location you are based, you need to check what all systems are available and audition the same....that would give you a fair idea of performance and possibly steer your requirements....
How big is your place? It then all depends on what speakers will be used.....if you want clarity, you may need to increased your budget....every AVR being sold has its own pros and cons....more the features ...more the expense....
Each one of us has our own preferences, sound tastes (more bass or treble)...bottom line trust your ears, audition with your kind of music and make a proper decision..do not rush...
If budget is tight and if you feel you may change your system regularly after sometime then go the pre used route and see for pre owned systems on sale on hifiads.com, in this site 'For Sale by owner' and olx....
A system which can provide smooth room filling sound with ample clarity at 50% volume is the one you should look for.....
All the best...read posts under Home Theatre and What should i Buy...these posts will give you ample guidance
Yht196 HTbi is good from above choice. It's good for Music and movies under your budget.
It has lot of good features like ARC (sometimes doesn't work), 27 different DSP programs. Voice is very sharp and excellent quality. There are few drawbacks like no USB, Room correction tool, speakers calibration etc. finally it's value for money
