Hello all,
I have been visiting hifi vision for quiet some time, just joined.
I am newbie DIYer and just bought this kit :
Currently, I am constructing the cabinet with MDF boards. I will upload some pics soon. This weekend, I will be assembling the electronics/cross overs.
http://www.madisoundspeakerstore.com...a5.3-mtm-pair/
Zaph|Audio - ZA5 Speaker Designs with ZA14W08 woofer and Vifa DQ25SC16-04 tweeter
http://zaphaudio.com/ZA14W08/ZA14W08-datasheet.pdf
I am trying to figure out a matching amplifier with 75% focus on Sound Quality (40% Mid + 35% High and 25% Low, is the priority I usually like in sound).
Datasheet says, the wattage 60w continuous 8ohm, and in this range. So, please advice, whether I am reading the figures correctly. If I want the best quality sound from the MTM I am currently, building, should I stick to 60W max for the amp or can I go a bit higher say 80w 8ohm?
Please enlighten.
I am looking at Marantz 6004 price range. I am open to Yamaha, Denon and few others as well. I believe usually Japanese brands should give better reliability and support and their components and QC are of longer reliability, to my perception!
I liked NAD 316/326, but, reading some issues related to reliabilities. Rega/Rotel/Musical Fidelity, I am not really sure about their reliability/support, in case of problems. Btw, I am residing currently in Muscat, Oman.
I might be getting a Logitech Squeezebox (or equivalent, since this is being discontinued! Any recommendations? or Network Receiver?), and source will be mostly PC based music/video storage or streaming. So, I am not really planning to put too much money on a CD Player, rather, may be a network receiver or equivalent, but, that is later. I also would like to watch HD Music Video contents (downloaded)/recorded shows a lot through a HD Media Player (I have AC Ryan with SPDIF). I also like to connect these system to for TV output (HD Satellite receiver) so that, I can watch those HD TV shows/concerts/video songs.
Please also advice, whether I can bring in AV Receivers (Denon AVR) into this comparison, since, I want Quality Sound (Jazz/Classical/Rock/Reggae/Indian (mostly Tamil and Hindi)). My believe is there is a significant amount sound quality degrade if it is AV Receiver. Am I correct in this?
If it is AVR, I am inclined towards Yamaha/Denons, but the outputs are higher than the Zaph recommendations (60 watt 8ohm as per datasheet). Btw, I am NOT planning for a surround system though.
Lastly, the room is a approx 15ft x 15ft size.
Sgmuser
ZA5 Data :
Nominal Impedance 8 ohms
Thermal power handling 60 W continuous
Free air resonance 65 10 Hz
Sensitivity 87 2 dB/W/M, 2.83 V
PARAMETERS
DC resistance Re: 7.1 (ohms)
Resonance frequency Fs: 65.835 (Hz)
Maximum impedance Zm: 32 (ohms)
Mechanical Q factor Qms: 2.1318
Electrical Q factor Qes: 0.5584
Total Q factor Qts: 0.4425
Equivalent volume Vas: 5.23 (l)
Moving mass Mms: 7.200 (g)
Sensitivity SPL: 87 (dB)
BL product Bl: 6.154
Effective radiating diameter D: 95 (mm)
Effective radiating area Sd: 68 (cm^2)
Voice Coil Inductance Le(1K): 0.37 (mH)
Linear Displacement Xmax: 3.25 (mm) (one way)
Please enlighten.
Sgmuser
ZA5 Data :
PARAMETERS
