Need advice 32" LCD
kalakal78
I am looking for a 32" LCD TV in the budget range of about 21k rs.
I might be using only normal cable connection for another year, and watch movie from my harddisk (TV w/ USB will work??). please recommend some good tv.
As well, need feedback on Toshiba 32" LCD TV 32AV800E. How good is the TV ? Is there any authorized service center in Bangalore ? ..
Need feedback on
a. SAMSUNG LA32C350 . EBay quotes 20k without wall-mount. Is that worth enough ?
b. SONY BRAVIA 32" KLV-32BX320. Ebay quotes 21.75k with wall-mount.
Thanks in advance.
The ones you are buying from ebay are just grey market dealers,you can get the same in bangalore grey dealers located in sukhsagar mall gandhinagar.
Try getting a 32CX520.
Sharp LCD TVs are not well publicized and marketed in India but their recent models such as LC400M are worth considering. The picture quality of this model is far superior to Sammys/Sonys/Panas when I saw them in a Bangkok showroom recently. Their models are also available in India.
Do you mean, there wont be proper warranty coverage if I buy from ebay ?
Yeah, coz the bravia u mentioned is available with sony india warranty is 29k. And the ebay deal which you are looking for are grey products and some sellers give dealer's warranty, not the sony india warranty. Better try to a local gret market you will save about 4-5 k depending upon dealer.
I got same model price here in chennai at 19k and in 24k you will have the CX520 model. They dont offer any warranty.
Hope it helps you to decide.
Yep, thatz helpful. Thanks for the information.... I am bit tentative to go for something without any warranty...
Can someone give pointer to a best deal for a 32". As I said my budget is about 20k - 22.5k; with atleast dealer's warranty.
