need an advice for audio out
fabyshahul
hubli
my new samsung ua40eh6030 is having no audio output.
but a headphone jack is there. i conneted it with my creative 2.1 speaker.
it works very nice.
will it makes any problem to tv
or can i use this jack permanently for speaker
It should not be a problem if the speaker system is an active one i.e it has its own power supply.
This is because the audio output is not driving the speakers i.e the TV is not loaded. No current is drawn from the TV if the speaker system is an active one.
it works very nice.
You can use that headphone jack for any self powered devices or sound bars...
Alternatively if you jusy watch stb and not usb from tv then you can take the audio out from stb and connect to speakers. .
Sent from my GT-I9300 using Tapatalk 2
The 2.1 Creative speakers are using own power-amp to drive the speakers. You are only using TV out as a preamp. So there is no harm for TV.
FYI : Never use big driver speakers directly from the headphone out. You should always use it with any amplifier.
