Need Expert Advice - TV audio thru IPOD DOCK
sunilgct
India
Hi Experts,
I have a logitech s715i Ipod DOCk. The sound from Iphone/ipod on the dockis awesome.
DOCK also has a 3.5mm jack .
So it possible to connect the IPOD DOCK to TV and have the audio from TV played through IPOD DOCK.
The TV is pana Plasma (42PV8).
Need your guidance has how to play the TV audio through the IPOD DOCK.
Sun
Yes its possible. Get a Stereo 3.5 mm to RCA Cable. COnnect the Stereo end to yr ipod dock or just the ipod and the other end to your TV .. At the back you will find Audio output .. jus plug in the RCA (Red and white most probably to the inputs on yr tv ) and you are done ... the sound will be sent out from yr tv to the ipod dock. But make sure the stereo 3.5 mm plug on yr ipod dock is marked as INPUT not output.
Thanks Yahoo for the quick response But how i do find out if its input or both input/output as such nothing is mentioned in the dock.
Sun
