Need expert suggestion for buying workstation
anilpatel
Anand
Dear FMs,
Please give your expert suggestion for buying workstation.
I am novice in the buying workstation.
Dear FMs,
You can provide more information, particularly the purpose, usage, expected performance, and of course, the Budget. At the lower end the cost of branded workstations with dedicated Graffic Card and 27" Monitor starts with Rs. 1.5 Lakhs and you can go up to Rs. 3 Lakhs with different configurations and add on cards/storage/memory etc.
I need to buy it for software development in Data Science field. I need GPU (memory size depends on the price). I am a bit flexible with budget as I want to make use it for a long time. I will use linux on the workstation. There are lot of online furnished workstation available but I am bit cautious.
