Need good speaker package for Denon 1611
samsam
Delhi
Hi Experts !
I have got 1611, 5.1. Suggest good speaker package in the range 50-55K with store name in Delhi
My usage 70% Music, 30% Movies.
welcome mate
check my thread in Speakers forum ''Building an HT for under 75k''. you'll find many options as I too have almost decided on 1611 and asked for speakers options to suit- specifivally those which are more musical
You can also add PSB Alpha HT1, HT2 and Defenitive Technologies Pro Cinema 600 and 800 systems to your list of auditions as they match well with the Denon 1611. But here you also need to factor in the Space where you want to put up this system as they are all Sub Satellite System and should be good enough for a room size of upto 200-250 Sq ft. Anything beyond that size then you will have to change the fronts with Bookshelf Speakers and you might also need to upgrade the center as well as the Subwoofer.
