Need Help. Connect Logitech Z506 to Toshiba 32" LED TV
shashankm
Delhi
Hi all,
I have a Toshiba 32" LED TV P2305. It is connected to the Videocon DTH HD STB via HDMI.
Following is the pic of input/output panels the TV comes with:
Then I have a Videocon D2H HD STB. Following is the pic of the same:
And then, I have Logitech Z506. Following is the pic of the rear panel.
I need to connect it to TV in a way that sound comes out in a true 5.1 or even simulated but as close as true 5.1 way. My room is pretty small and thus I won't require anything bigger than them.
An illustrated response would be much obliged with. ThanX!
Hi all,
simple stuff.. take the digital coax/optical out of TS HD box and connect to Z906 digital coax/optical.
go to TS sound menu... change to DObly digital from PCM and press blue button to save... you are done... TV is not needed in the chain.
on a side note : TS all outputs are active all the time so mute the TV when watching HD channels via Z906.
