Hi there all A/V enthusiaists.
Need your help and expertise here.
Firstly a lil intro and then the questions. I used to be a computer H/W geek during my college days, used to remain glued to Chip magazines before they were
named to Digit and then I got a Job
Not much has changed since.
I was inclined more to Audio and Audio gadgets during the last few years but now I want some expertise from you guys in the A/V section.
I recently purchased a 42" Panasonic Full HD 1080p Plasma TV. The TV itself has Vierra Cast and Vierra Link features so I can connect a Lan Cable in the
Ethernet port provided at the rear and this cable then goes to the Wi-Fi router..... This helps me use some inbuilt applications in the TV such as youtube,
Picasa, FlickR, Weather etc etc.
For a few days after buying the TV I used to copy the 700 MB DVD Rip downloads (that I earlier used to watch on my 17" laptop) on a Pen Drive, connect it to
the USB port in my TV and Watch them directly. Now the quality was decent. Not exceptionally good.
This was till, when a friend of mine forced me to buy a HDMI cable, and helped me download a BRip/ 1080p version of Transformers and Avatar.
When played via the laptop the video was mind blowing, although at times the video was still a little jittery, but not a lot.
The Hardware/ Software I already have is
- 42" Panasonic Full HD Plasma TV
- HDMI Cable
- Core 2 Duo Laptops
- BOSE Companion series 2 speakers (currently hooked to composite out from the TV)
- BOSE SoundDock used to play my iPhone and seldomly used as an Audio Out from my Laptop for gaming.
- Airtel IP Connection with 512 Kbps speed.
- 3.5" 1 TB Internal Seagate BaraCuda HDD 7200 RPM used with a USB Docking station for internal hard Drives.
- 2.5" 1 TB USB powered Seagate Go-Flex Hard Drive, purchased recently.
Now comes my main requirement.
After going through the plethora of information on this forum, I have decided to make my Home Theater using you Guru's expertise.
- Firstly, I want to buy a HD Media Player (WD TV Live Plus/ Hub or Seagate or Xtreamer or PlayOn HD or something that you guys suggest?)
Now my biggest question - I have read the reviews of close to 5-6 HD Media Players and I am a bit confused with the concept of HD Players v/s Video Upscaling to HD Video.
Q: Do all these famous Full HD Video Media Players in the market upscale the Video quality as well?
I mean to ask, when I play a 4 GB .MKV or ISO file, I am sure of getting a Blue Ray like Video quality. But when I play a 700 MB/ 1000 MB DVD Rip how would be the quality?
Would it be just like playing it directly off a USB Pen Drive using the TV?
Or else would it be upscaled and the quality be improved?
Please help me out on this one as I am terribly confused with this aspect? Are they any other HD Media Players with Video Upscaling , in the market as well?
Once this is sorted I need your advice in making up my mind to buy such a HD Player which fits my requirement.
I download a lot of movies using torrents. So the HD Player should be able to download the torrents in itself as well. May be it saves in the connected
external Go Flex hard Drive (in that case the drive also remains on, at all times),
- Else I buy a HD Player with inbuilt Hard Drive which saves the movies in itself.
- Else I buy a HD Player in which, I fit the 3.5" 1 TB Seagate SATA HDD that I already own.
Other than that, the HD Player should be able to play most file formats and have the best possible Audio Outs.
Again. I am not aware, which one is Better? HDMI Out or Optical/ SPDIF?
Further, I need suggestions for a decent, home theater receiver system with speakers for a good Audio Video HT experience.
Phew.....
Thats a lot of typing for a first post. But I can go on...... Just too eager to get the inputs from you guys.
So Hemant, Dheeraj, Phantom, NetFreak... and all the other genius' out there. Please help me out
Thanks in Advance.
- HDMI Cable
Phew.....
Thanks in Advance.
