Need Help in Buying 3d Blue Ray Player
ram_81
Chennai
Hi Guys,
This is ram here, good to be part of this forum.
I recently bought Sony 46 NX720. i am just trying to get a good 3d blue ray player, my main requirement is that it should support 1TB external Hard Disk through which i will be able to play movies in all formats.
Your inputs please.
Ram.
If you are looking for a versatile player to play any disk format as well as play media files through USB with an exterrnal HDD then your best bet is Oppo BDP 93 which is a Universal player and it can also be made region free after installing a Hardware Kit.
Thanks Ashish.. But i have a budget constraint of Rs.15 to 20 k max because i just put in a lot for the NX720, Any suggestions that will fit this budget?
Hi Vikram,
Thanks for the link but does this model "Samsung 3D Blu-Ray Player BD-C6900" support 1TB external hard disk?
Ram.
Thanks baiju, but i guess i need to see if it's region free and also if it will support 1 TB External HDD
got c6900, supports 2 tb external hard disk, played few 1080p movies,, superb, but itdid not read direct blurray copy file. i had avatar1080p bluray disk files50gb .. but it read all other files well
Hi Ram ,
I have checked 500 Gb HDD , working perfectly sharing some pics ...
I will also arrange 1 TB HDD for you with my Samsung 3D player C6900
[img=http://img839.imageshack.us/img839/5497/img2011071701148.th.jpg]
[img=http://img200.imageshack.us/img200/6531/img2011071701145.th.jpg]
__________________
vikram
hi, there is a model Kaiboer 750Li which is a media player cum bd player. It is region free too. However it is not 3D.
