Need help in deciding a TV
blackwidowsea
Wakanda
I am planning on purchasing a 55 inch TV.
I would use it for watching movies/tv shows and gaming with my PC and PS5 (hence would need at-least 2 HDMI 2.1 ports), hence would would 120+Hz refresh rate.
My budget is around Rs 60k. Can increase it if its worth spending a bit more.
I have found out two options within my budget:-
1. Hisense U7N
2. TCL C755
Would be great if you guys could help in deciding which one is better, or there exists a better option in similar price range.
If you can increase your budget, go for OLED Samsung or LG, trust me, you will not go back to any other TV, Picture quality is unmatched
Yeah, I am not sure I want to spend almost 2x on it for now. Maybe later on for next TV down the line.
I have a better experience with Hisense brand compared to TCL
Thanks, will check which one is cheaper in the next sale, currently both are available for around 60k.
