Need Help in deciding the TV
raj_krish
Hyd
Hello all..
Please help me out in choosing the TV of below models:
SONY BRAVIA 40R452A 40
Samsung 40F5000 / Samsung 40F5100
Can suggest me more models(FULL HD) with good picture quality
Thanks in advance
hi,
if ur willing to spend 65k go for Sony 42w700b 42inches led tv. if u need 40 inches wait for few days, Sony 40w600b 'll be in market soon.
hi...My suggestion would be...to stick to top series from any brand. SONY R series is not something on its top line, so would not recommend. Instead W700B can be tried, if you can stretch ur budget a bit...else if you want to stay with Non-Smart Good LED TV, you can try Toshiba 39 inches P2305...you should get it in less than 35K with 3 years warranty.
My budget is limited to 40k :( so am trying them in gray market.
Please suggest me the models below 45k and vfm
I dont require smart features just a full hd which good for hd and sd
Thanks for the replies
The best option is to do some window shopping....go to a Vijay Sales / Reliance Digital / Croma / E Zone and shortlist the brands / models which fit your tastes and budget.....then check the price and most importantly the warranty options....Sharp models like Toshiba is offering 3 years warranty......given the fact that LEDs / LCDs only last for a short time....you need to reconsider your options....
Hope this helps...
I was in a similar situation so finally decided to go for Toshiba 39" P2305 Due to Its VFM offering.
What i observe was there isn't much difference in PQ btw Toshiba & the costly options. Then why pay more. thanks to the forum member for helping me out.
Checked Toshiba 39" P2305, but is still like the samsung f5100 and for the price thosiba is good.
Found one panasonic 42e6d for 54k is it worthy to buy?
Or should i take sony 40r452 for 35k
Need suggestions....
E6D is worth it.. VFM but if your budget is 40k then Toshiba P2305. The samsung is also good but i didn't see any difference in the PQ n i had made a side by side comparision with the same model thats why even i bought toshiba.. Then its upto you! Buy the one which you like more
go for the panasonic e6....it has got fantastic picture in both HD and SD....another option would be 42w700b...good in both SD and HD...
Hi...
Which one did u decide upon...since even I am in the same situation...with models and budget..thanks in advance..;)
Take a pen drive with regular SD video and some HD videos and demo on ur own and decide.
Personally having demoed the w700 during my purchase of w850a it is very good.
Planning to go with 42w700 in grey market or will take Samsung f5500
hi raj which one did u buy.....by d way 42w700 in grey market how much did they quote ?
Also a local sony dealer offered the above model for 57.5 k :( do u think it is a good price !?
