Need help in Finalizing the setup
Gagn
Bengaluru
Hey Guys!
I have finalised the below
Denon 3700
Q Acoustics 3050i
BenQ TK700STI
need help on below
Q Acoustics 3010i v/s polk signature s15
Polk monitor XT 35 v/s polk signature ES 35
BIC america pl200 v2 1000w v/s Q Acoustics QB12
Finolex 1.5 sq mm v/s gearit pro OFC 14AWG (substantial price difference)
Also please suggest if you have anything apart from above
Hey Guys!
Denon 3700
Q Acoustics 3050i
BenQ TK700STI
need help on below
Change subwoofer to jbl stage a120p.
Stay away from sealed subs in this price bracket.
Hey Guys!
Denon 3700
Q Acoustics 3050i
BenQ TK700STI
need help on below
If you are set on 3050 why not go for all QA setup?
As you are in BLR, just have a look at Indiq offerings. Worth a demo for sure.
Why not go for an all QA setup - centre, surrounds and sub ?
The QB12 sub is really good.
Oops - we both posted the same thing.. :)
Go with QA setup except sub. I recommend Bic America PL200 II for sub. It's really vfm sub and bass is also very good.
Hey Guys!
Denon 3700
Q Acoustics 3050i
BenQ TK700STI
need help on below
Audition the Polk HTS 10 or HTS 12 subs....BIC America H100ii these are really good too VFM
My recommendation would be to go with 2 core 1 sq mm cable from Finolex or Polycab. Thicker cables add a lot of stress to the AVR due to their weight and stiffness.
If you feel the need, you can go with 1.5 sq mm for rear speakers as they will run a longer distance, but 1 sq mm should be sufficient for front speakers where the distance will not be that much.
See this article for recommendations on length vs gauge https://www.audioholics.com/audio-video-cables/speaker-wire-gauge
