Need help to build 12" active sub for yamaha avr
Naveenbnc
Hyderabad
Hello All,
I want to build a 12 inch active sub to use with Yamaha YHT196.
(Budget is 10 to 15K) Excluding wooden cabinets.
Can you give suggestions on the below options please...
OPTION1: A plate amp kit to add to my existing passive sub from YHT196
OPTION2: A good amp kit, and 12" subwoofer.
OPTION3: A suitable amp and 12" subwoofer from CAR audio systems.
(Car audio components are easily available everywhere in hyderabad. I will take care of 12V power supply etc)
Thanks & Regards
Naveen
