Need Help - TV and Stabiliser
dheerajg77
noida
I really need help. I bought a 65 inch LG OLED TV 2 weeks ago. Since its an expensive TV so i bought "V Guard digi 200" from amazon, but here comes the problem. When electricity goes then it switches off my TV. My whole house is already protected under "Luminous Zelio 1100 Since Wave" inverter (but not ACs because i have taken AC off from inverter due to huge load that AC takes) so i am not sure why TV is switching off. Please help. I live in society so when electricity goes then power goes for 30 seconds before coming to society backup. Just for 30 seconds, I got Luminous inverter. which is working fine from last 2 years. But I am not sure why TV is switching off when power goes. Ideally my inverter should not let my tv to switch off. What I am missing
Did you try connecting it directly to the inverter line without the stabilizer. Does the stabilizer have a cutoff timer that prevents the TV from switching on.
i didnt test that. i will definitely try that. Though i want to add something. Before buying this TV, I had a Samsung 50 inch TV from USA which was connected to Step Down Blue Bird stabiliser. Both TV and stabiliser were bought 2 years ago. In past 2 years, i have never seen this TV switching off whenever power goes away. So could it be this VGuard stabiliser. I shifted this old TV to other room along with Blue bird stabiliser. I was thinking to use that stabiliser and try connecting with new TV but thats a step down transformer that converts 220 V to 110 so not sure if that stabiliser will work with indian 65 inch OLED TV
I dont know much @ this,but at my time engg switched some switch up and down .at the back.after that problem not solved so he contacted compony and change the software.he said sometimes both product don't mach each other Freq.(180 to 230 instead 150 to 230 like that)
Probably it should be the new stabilizer but since this is 65 inch tv, also check the load as you had mentioned that all light connections are connected through this inverter. Switch off/disconnect some of the light points and try if the TV works.
