ramvalleru
Since i am setting AVR in my living room, i don't want to go with 5.1 speaker system.
I am either going with Yamaha RX-V373 or Denon 1312 due to budget constraints. I will go with a center speaker with some bass and two book shelf speakers. Is it good to go with this kind of setup?
Here is the living room setup and still work is going on.
Since the corners are very wide, even if i place speakers on each side of corners it is not effective. So i decided to go with an AVR which is Yamaha or Denon for my budget, then buy a center speaker and two book shelf speakers and place it on both sides of wall mounted TV.
What is your opinion guys?
Yamaha RX-v373 will be better than denon 1312 because it supports audyssey setup. How the sound will be on both of these receivers. Is there any receiver will be great in 20k price range. Also let me know the current prices.
Because i am going to buy this with in a week, i need your help.
