Need help with setting the speaker cables
hemant1909
Gurgaon
Dear friends,
Just bought Pioneer 523k + AJ 5235 speaker for my HT setup. To my dismay i hv found that speaker cables are not included with it. I am surprised as I had onkyo hts 3400 before this and it had come with all the speaker cables.
Please suggest some good options for cables for my setup.
Hemant
Htibs come with cables included as they are meant for connecting right out of the box. So now you need 5 speaker wires. I think 16awg should be good. Also you will need a rca subwoofer cable which is different from what you got in onkyo.
Thanks rayvonnee for your reply. The subwoofer has come with RCA cable , So I have to manage for speaker cables for all the other speakers. Could you or any other knowledgeable person suggest the best VFM cables which I can buy !!!
Thanks in advance
If these are costly for you. Check Your Local Store for decent Quality Speaker Cables. I think even mx speaker cables are decent ones. Cheap ones are generally rs. 12/meter. The ones i got were rs. 22/m 3 years back. I had to conceal them in wall and had not thought that i would go in for a dedicated ht that time. You can definately buy them from hifimart.com and dac is very good quality. You can check the requirements accordingly. Dac Will cost you around rs. 111/meter for 10meter roll 16awg.
If your subwoofer cable is not of good quality then would suggest to also buy subwoofer cable of good quality
