was looking for some info and help with some diy dac kits that i identified. was looking at wolfson since i had that in my cdp (cambridge) - it used dual wm8740 dacs and was very happy with its dynamics and sound stage and clarity. yes, could be a little clinical, but matched perfectly with a slightly warm sounding nad
of the two kits i saw, one has dual wolfson wm8740 dacs. the other has dual wolfson wm8741, which reviews say is a decent improvement over the 8740.
1. does anyone have any information or experience with these kits. specs say that the 8741 plays 192khz, and the 8740 plays only upto 96 or 48khz (pl correct me if im wrong). what would be the implications of this, both in sound and also ability to play files / formats.
2. also i see a yellow rca connector on the board, apart from the red and white. im assuming the red and white are audio out. is the yellow a video out? if it has a video out that would be perfect. else i could connect a separate cable from the computer to the tv - just for video out.
3. does this connect to the computer via usb?
to give you an idea of my setup, i would be using this as a dac / external sound card for my computer. this would then connect to a nad pre onto a nad 272 power amp. speakers are monitor audio silver rs6. there is also a tv that i would like to connect to the setup for video to watch movies / youtube. video through the tv, and audio through the amp / speakers
below are the links of the kits
DAC Dual WM8740 Coaxial USB Decoder Board WM8740 DIR9001 PCM2706 | eBay
24BIT192K CS8416 PCM1794 AK4399 Double WM8741 DAC Decoding Board LCD Softwave | eBay
