need inputs on inear headphones with mic for iphone 4s
amateur
chennai
Hi All,
these are the ones that I have shortlisted :
1. apple IEM
2. bose mie2i
3. Klipsch s4i or x10i
4. seinheisser mm70ip
requirement : musical, should be good enough to take the calls in mobile, should be comfortable while wearing i.e. for an hour and half minimum.
I did read the other thread on this (IEM by AP Jain), not sure I can get etymotic in India yet.
Budget: 5 - 10k,
How much is the x10i? Guess the TF10vi would fall into your budget as well. It all boils down to sound signature preference in the end.
Got s4i for my brother which he uses during his work out. Probably due to perspiration, it's Mic stopped working. Got it replaced under warranty. few days later the replacement also had the same problem.
Conclusion, it is not a good design for use while workout. Other wise it is excellent for sound quality.
I am personally using sound magic e10 which also have a Mic and iPhone control. Better than many headphones double it's price of 2.3k.
Sent from my Nexus S using Tapatalk 2
