Need receiver advice!!
insane79
Bombay
hi,
i am planning to upgrade my yammy rxv661, i m thinking of getting either denon avr1909 or 2309, i got jamo S606 7.1 speakers, here are the specs-
front-
S 600
surr-
S 600
the denon 1909 is 90watts 8ohms While the 2309 is 100watts 8ohms, which of these receivers will be good enough to power the speakers offcourse without blowing them up;)
thanks guys..
hi!
i think you can use the 2309 without damaging your speakers. the jamos are 130w at 6 ohms(continuous drive). but the dynamic power handling is 210w. whereas the 2309 is 100w at 8 ohms. so, driving at 6 ohms, both the short term and the long term power will be within safe limits.
thanks for the advice, dont know if i will be able to notice the difference between the 1909/2309, the 2309 has only 10watts more power, so dont think i will see a diff really :rolleyes:
wat ur'll guys think of the denon avr1908?? is it good?? heard they are going cheap everywhere since the new model is out...
