Need some Suggestions for Ford Figo ICE upgrade. My budget is Rs. 75000/-
dheep4225
India
Hello,
I bought a Ford Figo Duratec Titanium recently. I want to remove the stock music system and upgrade. My budget is Rs. 75000/- I listen to heavy Metal & Hard Rocks mostly. So I need subwoofer too. kindly suggest me....
Where are you located exactly?
For front's go for Rainbow Soundline comp's, for the rear you can go for a pair of Focal Coax's. For the Sub choose an ID in a ported box. For the Amp's, use DLS or a cheaper equivalent?
If you are located in Delhi, you can contact Motor Concepts.
I'm looking to get advice on what the best amp or amps would be for the setup below
JVC KW AV50 DVD/CD/USB Receiver or Sony XAV 601BT
Polk Audio MM6501 in front.
Polk Audio MM691 in the rear.
Polk Audio DB1212 12'' Subwoofer Enclosure.
Can I use Polk Audio MM6501 both in front and rear?
I'm into classic rock and hard rock... so I'm looking for sound quality with punchy, accurate, and clear bass, mids, and highs. I don't listen ridiculously loud most of the time, but I would like that capability... and I definitely want clean sound.
