Need Suggestion - Good Bluetooth earphones with mic and noise cancellation
haisaikat
Kolkata
Folks, I need of your suggestions for selecting a good noise cancelling Bluetooth earphones that works good for phone calls and can eliminate surrounding traffic or chatter noises from my voice stream so that other party should not hear them. My budget is 3500 rupees max.
So far below options shortlisted with only Amazon reviews but open for more
CrossBeats PULSE IPX5 Bluetooth In-Ear Sports CVC 6.0 Noise Cancelling Headphones with Built-In Mic, 8 Hours Playtime, 272E, Case https://www.amazon.in/dp/B01L7ROIJ8/ref=cm_sw_r_cp_apa_i_ruMGBbKZQFYBV
Costing 2999 rupees
Tantra Power Boat Bluetooth In Ear Sweatproof Noise Cancelling Headphones (with Extra Bass and aptX) https://www.amazon.in/dp/B078H6YY9C/ref=cm_sw_r_cp_apa_i_3uMGBbH5VERP1
Costing now 3999 buy at times Amazon sells discounted for 2299
Sennheiser CX 275 S In -Ear Universal Mobile Headphone With Mic (Black) https://www.amazon.in/dp/B008V6T1IW/ref=cm_sw_r_cp_apa_i_vvMGBb2NEGP7
cheapest having price 1600
At the price every noise cancelling feature is a gimmick. The best passively isolating earphone with foam tips would be the best bet at this price.
I do understand that at this price active noise cancellation will be difficult but what about the claims of having unidirectional mic or other engineering Tweeks. Should I expect nothing at all? Or something is better than the other which is what I am looking as Suggestion of someone has gone this route. Certainly for a non audiophile reason do not wish to spend a fortune. Then again to your reply, not looking for a noise isolation with foams as that is just me. It's the other party I am worried more of.
You should try "Headset with 'noise reducing/cancelling' mic". I feel it's hard to get what you want with inbuilt mic headphones especially if you are in car/bus with windows rolled down.
I use Jabra evovle 65 and must say it still can't silence the traffic and other loud ambient noise for ppl on the other end despite the relatively high price tag.
So what you are saying is that a pricey option like Jabra evolve 65 is still not cancelling ambient noise? Active cancelling ones are even costlier.
So any point buying a headset for 3k? Shouldn't I got for just 1k?
Well...it does cancel ambient noise to fair degree but can't shield traffic noise. If calling is what you need then check from below list or try similar in your price range
https://www.bestbuy.com/site/shop/headset-for-phone-calls
Plantronics Voyager Legend Bluetooth Headset https://www.amazon.in/dp/B009ZNGDTA/ref=cm_sw_r_cp_apa_i_MXEJBbVYZ32S4
If Bluetooth is not mandatory then you may get descent options in wired.
Bluetooth is not a mandatory ask. I am fine with wired but what i see is that in this price point of Sub 3,000 rupees most are merely noise isolation ones and not cancellation which is like blocking the ambient noises from entering my ears but not the mic although some market unidirectional capabilities of the mics and use for passive noise cancellation. Any wired suggestions?
