Need suggestions for buying bookshelf speakers for under 10k.
acoust1k
Bengaluru
Hi all,
I am new to this forum. I am looking for suggestions to buy speakers for my laptop (Dell XPS 15 9560) primarily for listening to music. My room dimensions are 14 ft x 12 ft approx. My budget is 10k. I am located in Bengaluru. It would be great if you can recommend any stores/shops where I could buy it for good price.
Thank you :)
Hi all,
I am new to this forum. I am looking for suggestions to buy speakers for my laptop (Dell XPS 15 9560) primarily for listening to music. My room dimensions are 14 ft x 12 ft approx. My budget is 10k. I am located in Bengaluru. It would be great if you can recommend any stores/shops where I could buy it for good price. Thank you :)
Try to look at chinese amplifiers SMSL / FX Audio D802.. One forum member was abt to sell it, i guess Bangalore.. These amps have ample power for near field listening.. Also these amps come with various Digital to Analogue converter..
You can consider getting an used old hi-fi stereo speakers from pioneer/aiwa/sony/philips for 2K thru OLX and you got yourself a good system..
Later when you have sufficient budget, upgrade to better speakers..
This way you have flexibility of upgrading better components in future..
