Hi guys...i need a new tv that will be used as both tv and a computer monitor.
Requirements:
1. Easy on the eyes as i will be using for 8 to 9 hrs daily and i have low vision and dry eye problem
2. 32 inches or less preferred
3. Should be full hd and have all the smart features.
Will be used for coding, surfing and watching videos.
The closest i can find for my needs is the 32 inch LG La6200 model...comes wid magic remote which i like a lot.
Will this model be good and easy on d eyes because it has an ips panel??
Or is there any better option available...the samsung h6400 and other 2014 models...will they be better...i really need something like d magic remote.
There is no limit on budget and would be buying on this weekend.
All suggestions will be appreciated. Thank you!!!
Requirements:
