Need to buy Samsung 32 Full HDTV as a Monitor.
diliplp
india
Time to replace my Dell 22inch Full HD monitor.
preferring 32inch as 40 will be much bigger for monitor, though main purpose is movies and games.
Getting good discount in Samsung only :), so not considering any other brands.
Purpose :
1. Mainly BRRips, 720p and sometimes 1080p too.
2. Gaming at full HD
3. TATA SKY HD
After reading this and many more forums and googling I finalized
1. Samsung LA32D580K4R ( 40w audio ( D550 has 20w, DLNA )
Considered
2. LA32D550K1R
3. LA40D550K1R ( worth extra 10k ? )
4. UA32D5000PRMXL ( HD Ready)
5. LA32C650 ( Serios 6, Ultra clear panel, work extra 5k? )
Budget is around 30k, panel lottery is still an issue, had to leave it on my luck !!!
Please guys give your inputs, you suggestions are welcomed.
Experts, Please advise !!!
I did search forum and did google enough.
Just wanted a final advise on my selection before I buy it :)
Thanks for reading.
I believe LA32C650 should be your best bet. You will get max features and arguable the best PQ out of your shortlisted models..
Thanks prankey !!!
LA32C650 has 100Mhz motion flow, read its not good for games ???
thats why I dropped it. Price is too high for 32 incher, rather I buy LA40D550K1R buy paying 5k more, what you say Bro ?
Anyone else can throw some more light ???
^^ Is the 32D550 good as a Computer Monitor? The main issue I am myself concerned with using LCD TV as a Monitor replacement is text rendering which I have heard changes from model to model with some worse or better than others.
Anyway, I saw the 32D550 at a chroma store yesterday and despite its 33.5k price tag the visual quality (with Airtel HD) looked much better than the Sony 32EX710 which is priced 12k higher.
