Need urgent imac studio setup information
Status
Not open for further replies.
varma_vikas
delhi
Hi all respected people,
I am setting up a studio system with IMAC and i have selected few products to pair with imac. Few questions i have:
1. If this setup was chosen for an imac , what extra is needed?
2. What cables/ connections?
3. and is there something better than this OR recommended OR cost effective?
Below, i am providing the full information of the products i have chosen. Please help me with your valuable suggestions.
Important
If cable are required for the connection - please let me know the cost for a spare cable/connection.
CAMERA
  • Canon EOS 70D
  • Lens — Canon EF-S 10-18mm
Pngaa1QIZVBHhT-KxRI_zOFJg-4sRwhAw4eKoS1DueXB9KDCbITVF_2jvdjdOjHaXnNOxDWQvu6CaEtbvpf9ExYL0s8NjhYW1CKY9agMPtE5WHjPYADA1oNY1-09pwnBV4AvpjM6
SD Card (need 2)
  • SanDisk 64GB SDXC UHS-I Memory Card
d1SrL7uy3MIUnqeVFtmS-Hnpm6u0goFVhBszOsBjyVTkKPkKdyBmO3rEZiFKRjt5_bKhS_6b_xUrSDwR0SzafNMVnGmcr2whHDDTrol6HWg8ACQ9kPBfO5w34TM3LXibDyCj-d_3
TRIPOD
Manfrotto 755XB MDEVE Aluminum Tripod with Built in 50mm Ball Levele
http://amzn.to/2gt5vXs
gi3PGWBivqf1J6Dot8L0wZlZnex35YSAfrF1uYOd0XLCtd0PBEOVLDZ6T4WBlouf7JoYuwzOZkbDs8pIO-DI_5sW75xUYDzkysoenSA6mF6axC6MS8NVRNabRkoJOXD3_NEQquet
Video Head (Fluid Head)
Manfrotto MVH502AH Pro Video Tripod Head with Flat Base, Fluid Pan, Drag System, Built-In Counterbalance and Calumet Quick Release Plate (Standard Packaging)
http://amzn.to/2h61byc
JOBY GorillaPod SLR Zoom.
Flexible Tripod with Ballhead Bundle for DSLR and Mirrorless Cameras Up To 3kg. (6.6lbs).
https://goo.gl/Jk2Uzm
SY44h4B0Zvhc3k8JtWfwnvpjMpvAScJw3E3tBC6VwCF4nypPcK14E7Z3B6xe5LCGLpBUVZqzEiSzARa8_qnVZJsD3f4stM4Y8ct4VdhGtwZU6UFzBmukziP53_I4NnBPOSj1KyCS
MICROPHONE (need 2 wires in case)
RODE VideoMic Studio Boom Kit - VM, Boom Stand, Adapter, 25' Cable
http://amzn.to/2gliyvz
OR
RODE VideoMic Studio Boom Kit from DVE Store:
http://bit.ly/RODEStudioBoomKit
bteSnF5N_6ebiwLbYc_Zb72cojtdRC1KU9grA_Lox40qrXjJjG0Y6HH7Wq3A5f8lSaS6INnqx1mmd96NPWHl-kduzJ-QBQv6GoFxAQycI5GU4GdofnGbwTCwZmNDrxJ-aIyN9r0n
LIGHTING (need battery extra just in case)
Lighting — Prismatic 18" LED Halo Ring Light with Stand
http://amzn.to/2gVF5yD
HWmEToDjWagwGqisdzoT6pB7zQ8Gp7jvHCQwTo-W1gCzxW0Ev3JR70DmiA3b1h7MM8FwTjs1-u1cmkHb6qNbSUHtbELCbKjCD5Gwl7ADjfn4YOAMT-u9oFx_hwRtkpav-_13Iz9t
NEEWER LED Light
http://amzn.to/2gJzXdO
NUr2xGXCg4U921m4trDT-gU4zO_JKB4QI03jkaVOtMUeVZ5HZ5VHs-nJRdSArsHlqhXYsoSXhxTDaHTWXGzEBIuwmBPkSklRz4LXTk9hdN1DJjlLdGv8Jmv51wkT2Y_w2Y_zNU0w
White Balance Card
http://amzn.to/2A1FAOQ
2pu916dj70a5f8vLdL_TyRvLc1UpuaWKlypXCNUWazQbS7q-7jAPWHhsRAGeXWasQGUvQiHApMguPrKzYDuODEEJWB9Mie9wF8DO0uFEOwWAOyOvvfPoamaU7jWExDCWCMYrjXQ4
MAIN LIGHTING OPTION 1
Lighting — StudioPRO (Set of 2)
S-600BN Dimmable 600 Bright LED Photography Continuous Bi Color Light Panel
http://amzn.to/2hdCUqb
AT_kgTjmMxi0MCvS1jvCAv3gORyiSzlsNlsdsTj28lrq8jOukTWamr3731xssd2DUQNtOsJ_vrbI6efSHaYDUCMU_rJ19qo0hdZFt4YlE0qkzw7VohvcqNgqb6iTuNoDJEFH6cL8
StudioPRO V-Lock Battery For LED Light Panels X 2
http://amzn.to/2bwRs0J
or
MAIN LIGHTING OPTION 2
Free DHL Godox LED Light Kit 3x LEDP-260C 3300-5600K Video Light + Light Stand + Roller Carry Bag Video Studio Light+battery
https://goo.gl/2yLF9M
kDPfqwB5I0Gg_LLnGkicq7EWHESS0BPkbMgZwpk0G__W2nL5Be0MexBDpC93AHBfPXUsgQf63nB3NDaio55Ii4O7t6_C385CWX_sWqxrB1M0u3ywx9uVmC_fOLx_D0kOHglG0LsE
Studio Speaker Setup
(When you are visiting the specialist, please ask him if this set up can connect to the imac for a home studio setup + are the cables enough or am I missing something?)
KRK RP6G3-NA Rokit 6 Generation 3 Powered Studio Monitor Pair
https://goo.gl/GM9zX8
smsD9y1cfZVgFa3DGDzi1H_zXuJkAlB7F-rvSKj_hEv36r7dIKb_F4mKGIeKnmxCUT8YRX4k0esVFeGTeUdmrXIbUt0405tjJvpz3idMpNbfl37oSZiCAcPTNql9iS1MUE8JQFo4
Audient iD14 High Performance USB Audio Interface
https://goo.gl/b2xyED
N-t3j4wr8EpILU1kEhqeg3600iWw-nmuVS-NF5daRJNA2p84hFkUaKG_J_uCOEqDy1Otd-MTgg7Q3UNtMXkdjomW-7efTT8slsfyp34XVauDOpn7UWl-ArqUX7-NUALDcN0YYMkD
Mogami GOLD TRS-TRS-10 Balanced Audio Patch Cable, 1/4" TRS Male Plugs, Gold Contacts, Straight Connectors, 10 Foot
https://goo.gl/dTP9pG
qWhb84MhS00obqD3pCkSIO5Q0ZFdLkF9hCilkB7NTgyJ9sPXouawVDYmDQATC97cfUEyYI84jbfNR_QQPgw2sVPcCrCGYBFCyI0DN_cE3QHeUWxqFAfTNoHDnUD86OWV8nxT01yr
Mogami GOLD TRS-XLRM-10 Balanced Audio Adapter Cable, 1/4" TRS Male Plug to XLR-Male, Gold Contacts, Straight Connectors, 10 Foot
https://goo.gl/1eT44v
GMDGyowQghyxi4Xt7lngradDZQsrVi7PvPqo6XF_zaiBQQEPtNjEdlvCioMvQPKD-ez-isJgxXFWAQpb0r4pyisrJ1R0L7ACpZipqz8gAcrfQti6S50wfvhNi-IwjqxGys_9RV2n
MOST IMPORTANT
Please ask them if they have protective casing that come along with these products to store these products if in case they need to be stored/transported.
After spending so much - it might as well be protected.
Status
