Need advice on water pump selection and its possible impact on AV equipments
First on the pump
My house is 3 storeyed and the pump will be placed in the 1st floor while the corporation water reservoir is at the ground floor. We intend to place a 700 litre syntex/patton tank on the roof of the 2nd floor (can be considered as the base of 3rd floor). The vertical height from reservoir to pump is around 16 feet and from pump to the water tank on the roof it will be another 26 feet. However the pipes will not be straight and including bends the total length is expected to be around 50 feet from reservoir to roof-top tank via the pump.
So my first question is will a 1 HP pump be better fit or an overkill. Second, I have been advised on two categories of pumps, namely BEE Pumps which have separate motor and pump joined using coupler and the other type is Mono pumps which is all in one device sort and costs lesser. The school of thoughts are divided, one group says that BEE pumps are more versatile and durable and can be serviced in emergency situation by even local technicians / plumbers and on the other hand Mono pumps have to be serviced by company people specifically and service can be an issue if something happen over weekend. However one plus that I was told for Mono is that it is much more silent than a BEE (seperates) pump. So confused, and need advice.
Second on Precautions for AV equipments
Our current pump is a 0.75 HP seperate motor separate pump kind of equipment running for the last 30 years with one change of motor in the recent past. But it creates hell lot of sound pollution and also induces vibration on floors, since it is ground floor, the vibrations are not so prominent in the 1st floor. But now my concern is that if the new pump is hosted in the 1st floor itself where I also have all the AV equipments (in my signature) placed, will there be any chance of damage to the AV equipments due to induced vibrations on the floor when the pump is running?
First on the pump
