ar.saurav
Hi all,
Need your advice on a new amp for my Wharfdele 9.5 speakers.(floor standing only) I am currently using it with a cheap 50w amp. But want o upgrade to something nicer. I am considering Yamaha AS500 and also a Rotel RX-950AX (which i am getting at a reduced price) there is a small difference between the pricing of both amps.
Rotel is 50W while the Yamaha is 85W. I am very confused and can't decide which one is better.
Also if there are any other amps they you may wanna suggest, please do so.
PLEASE HELP!
Thanks in advance!!
PLEASE HELP!
Thanks in advance!!
