mspriyan
Dear FM's,
Planning to construct a HT cum 2nd Bedroom in the terrace (10ft wide X 21 ft Long) . I have attached room plan that i have in mind.
Need your help in arrving at the electrical out points + projector power point + speaker points
Planned setup : (Which will be done in phases - Audio first then projector)
1. Projector : Panny PT-AE8000 / Epson EH-TW8100 (yet to have a demo)
2. Audio : Denon 1713 + Polk Speakers (7.1 Setup - yet to have demo)
3. Blue-Ray Player (Suggestion Welcome)
4. Xbox (probabaly after some time)
5. Logitec Universal Remote
6. Recliners 1+2+1 ( in 1 row with out steps)
7. AV Stand (Suggestion need for the brand - or can we build with wood)
8. IR transmitter in front below the screen
Questions in mind:
1) Electrical points - how many & amps ?
2) Projector power point - what amps should be provided
3) HDMI cable from AVR to Projector - should it be provided at the time of construction or can this be done latter? (will be going for a false celing later)
4) What would be the maximun screen size suitable for my room size?
5) Is it advisable to have the speakers (centre & front channels) behind the screen? if yes, do we get acoustic transparent screens in India?
6) For the IR transmitter setup - any consideration to be done at the room construction stage.
7) AC - is 1.5 ton enough?
8) Speaker points for 7.1 setup - especially fornt , middle channels.. Can i place the sub-woofer in the back?
9) Should the speaker cables be included at the time of initial wiring itself?
10) Any other points I am missing?
11) If dimmer lights to be used - can this be added later at the time of constructing the false celing?
Questions in mind:
