hi guys,
this is kalpesh bhatti from rajkot, gujrat, india. i am new to this forum and also weak about knowledge of home theater system so i request you guys help me i plan to buy a 7.1 channel home theater system my budget is around 70-80k so please guys help me and also that thing available in rajkot gujrat which place when i buy from
thanking you
kalpesh bhatti
Welcome to the forum !!!
By the way, you have a good budget too and so you need to make sure you get the best for the money you spend.
There are many posts which can advice you on the way to go. Even before you go get through those posts, you can have a look at my post here.
http://www.hifivision.com/home-theater/46707-budget-reciever.html#post529036
The above post will just give you a very high level idea of how to go about building your home theater. I will always suggest that one shouldn't be in a hurry to get the HT. Step by step is the best way to go.
Having said that and for your rough idea, you can divide the budget like this:
1. Receiver (around 30 to 35k)
2. Speakers (3 speakers Front-L/Front-R/Center + 1 subwoofer) (around 50k)
The above is just to give you a very rough idea and need not be exactly the same.
The next most important thing is audition. You need to visit a showroom who sells multi-brand receivers/spesakers.
For example, you can choose from these receivers and you need not limit yourself to this list.
Receivers:
Yamaha RX-V473 or RX-475
Marantz NR1503 or NR1504
Denon X1000 or AVR1913
Speakers:
Wharfedale Diamond 121 BS (2 speakers - Front-L/Front-R)
Boston Acoustics 26
I generally prefer bookshelf speakers over satellite speakers due to performance.
Take some time to go through other posts and post any new queries.
