new TV advice
aboauf
EGYPT
Hey guys
I am going to buy a new TV but I am really confused and It is too hard to choose as there are many models and I can't find enough reviews for every model
I am going to buy 40 or 42 inches TV i care mostly about the picture quality and also ghosting and blurry images as I watch a lot of live sports on tv...the models I am choosing between LG lA6200 , SAMSUNG f 5500, Eh6030 , F6100
which one would you recommend ?
I prefer Samsung than LG. my first led panel was LG and it given me trouble within warranty period and replaced the panel and sold it
Using samsung from may 2012 without any issues 37" model, good picture quality and build quality
Third one is toshiba with my parents, that is 8 months old and reasonably good build quality and good picture quality satisfied
if u r from egypt u can consider toshiba b coz my toshiba is manufactured in egypt, so u can get it at a bargain price
copy some different format videos in a flash drive and play in different models and decide a model
Hi Buddy i have LG 6910 and its awesome.. no ghosting or blurry images.
SONY W850 is great too, in fact smoother than LG.. BUT it suffers from clouding.
I own lg lm6200 and I like it , it is 3d aswell, la 6200 is 2013 version of this model ... Samsung Eh 6030 if I am not wrong is 2012 model and is 3d... So if so, stay away from 2012 models when 2013 models are available. u can also look at Sony 850 and panasonic et60 ...
You haven't given your budget, buddy but I'll definitely recommend Samsung F5500 and LG LA6910.
Samsung F5500 is 3D Plasma smartTV and LG LA6910 3D LED smartTV. Both of them have good reviews and their PQ is fantastic. You won't have any ghosting or blurring in live sports and no crosstalk in 3D.
You can also check Sony, Panasonic, Sharp but I would prefer those 2 models. You should take a demo of those.
Thanks I don't like the Toshiba designs I have seen here and I always tried SONY in my home tvs but SONY prices are crazy here
I only found this model here LG LA6210 not sure about the 6910 and sony prices are pretty high here
well yeah I think this samsung model is older but I really care more about the picture quality I don't think that I will ever use the smart features in anything and did you mean Panasonict wt60 ?
my budget is nearly 700 dollars but prices can be different here and most of the models I mentioned about the same price ...I am not sure if LG LA 6910 is available here I only found the 6210 model ,I only used plasma tv before and it suffered from burn-in so it was a terrible experience for me and I am not sure if such problems still occur in the newer models
I meant 2012 models means a possibility of getting a demo piece is high... So I wud recommend u to stick wirh 2013 models... As price diff in 6910 & 6620 is less, get 6910 if u want to buy lg, though 6620 should have same picture quality as 6910, as specifications are same... And I meant et60 only, it is 3d led from pana... Wt is also a good tv though...
I googled et90 but couldn't find it
