No Audio from PC spkrs --Need urgent help
Santanu Ghosh
Kolkata
I have connected my PC to my LED TV(ARC capable) through HDMI cable.I have a monitor though.
After switching the display from Monitor to TV(through graphics card settings) display is coming to TV, while Monitor is blank..no problem in this matter but audio is coming by TV speakers instead of PC speakers.
Changed audio settings of TV to external speaker but no audio from PC(only TV spkrs are off at that settings):sad:
Pls help
Try to change the sound settings on the PC to use speaker connected to the PC. If you are using windows on the task bar speaker icon double click or right click and select the use speakers to the option like analog/spdif/coaxial to whichever way you have connected your speakers with on the PC. You should be getting the sound from the PC speakers and the video on the TV over the HDMI.
I am using win 7 x64 with creative sound card.I have only connected HDMI cable and no other like analog/spdif/coaxial. Then what should I do ?
You need to change audio settings in the PC... more specifically the media player you are using in the PC. Change/set the audio output in the media player to PC speakers (would be HDMI now).
