Thought of setting up Plex Server to play media files,especially 720P & 1080P contents as up-scaling ability of
Shield is very good.In the process,found uploading of files in plex server and updating the files time to time are
cumbersome,hence explored the possibility of playing media files from external storage (Seagate 2 TB HDD)
and found a solution from youtube vidoe
Found above method of playing medial files is much easier than plex server method.
Format the HDD in "NTFS" format through PC and upload the media files
Connect the HDD to Shield on USB port : 2 (next to HDMI port)
Install file explorer apps like ES file explorer or FX file explorer
Open the HDD contents via above file explorer apps and play the same through media player services like
MX,VLC etc.,Able to play Video,Audio & image files.
