Nvidia shield TV display not visible via Marantz receiver
rajeshg_k123
Since many days I did not like the sound of audyssey of Marantz. So I reset Marantz 1506 and did all the setup. However only nvidia shield TV pro via Marantz there is no display, however if I connected directly to TV its visible.
Tried with different HDMI port, changed HDMI, still it's not working.
I also did factory reset of Nvidia shield with no luck.
Anyone with any help on this issue will be great help.
Also I have tried fire TV stick and Wii game Console via Marantz, display works. It's only with Shield TV
Option : 1 : Connect the nvida to TV and change the resolution to 1080P initially and later try connect to the Marantz,,, may work..
Option : 2,,, Switch on marantz first and then nvidia player
Option 3 : Check for updates of nvidia to latest firmware while connected to tv directly
Thanks for the response srinisundar..
Not sure what resolved.. with Marantz ON when I reboot shield TV, I could see the nvidia logo but after that it was blank screen. Later I switched OFF Marantz power supply and rebooted shield, waited for 3 mins (for booting to complete) then powered ON receiver. It resolved the issue.
Hi everyone! I'm experiencing the same issue. My 4-year-old Shield TV Pro has stopped booting up; it intermittently displays the Nvidia logo before going blank. I’ve tried all possible troubleshooting steps, including a factory reset, but nothing seems to work. My Shield TV is connected to a Marantz Cinema 50 receiver. Today, I connected it directly to the TV and attempted a factory reset using an external keyboard, but that was unsuccessful as well. I'm not sure what to try next. Any suggestions?
Do you have a USB stick inserted ? If so, please remove and retry starting up.
Wait for some time. May take a bit longer to start up.
I did that and almost all possible means to reset to factory settings. Now only thing that's left to do is side load original drive from the website.
Last try - connect to a computer monitor, instead of your TV, and try to boot up.
Do not reinsert the USB stick.
Somehow it worked for me.
