Nairrk
My Home theater model: Sony Blu-ray Disc/DV Home Theatre system BDV-E870
My TV : Samsung LCD, model: 46C550
Ports available in both units:
Home Theater:
1 HDMI OUT (ARC)
1 Optical port
1 Coaxial port
1 Audio IN L/R
1 USB port
Samsung LCD TV :
4 HDMI ports i.e (HDMI 1(DV),2,3,4
1 Optical port
1 Audi out (R/L) and component IN etc.- but no HDMI ARC
Recently, I have installed Jio Air fiber at my home. After the installation, I came to know that Jio STB does not have Audio Out Port.
Present connection set up: Jio STB to TV HDMI 1, TV Optical to Home Theater optical port - with this set up I get only 2.1 channel sound. As seen in some YouTube reviews, I have connected another HDMI cable from TV to Home Theater HDMI ARC port. With this set up, I get 3.1 channel sound, i.e. Surround Left and Right, Center and SW. Front Left and Right speakers not functioning.
Samsung owner's manual says: ...'' If you want to hear 5.1 channel audio, connect the Digital Audio out (optical) jack on the DVD directly to the Amplifier or Home Theater, not the TV''.
What I understood from above is that, the optical connection has to be direct from STB to Home theater and then HDMI connection from Home theater to TV (this set up was done when I was using TATA PLAY connection, and I was getting 5.1 channel surround sound.
Checked with Jio support team, but they are helpless and only way they suggested was to connect speakers via Bluetooth, for which my home theater does not have the Bluetooth feature.
I have been trying to get information about HDMI Audio adapter / converter/ extractor etc. but not getting enough ideas whether such connection will be helpful in this case or not. I am also trying to find if buying the Mi Box and connect same to home theater (Mi Box has got Audio out port and if connected direct to Home theater then it may get 5.1 audio) and then use Jio only for Wi-Fi until its subscription expires.
Any experts here can help out to find a way for me to get my 5.1 channel working in these circumstances?
Thanks in advance.
Nair
Home Theater:
1 HDMI OUT (ARC)
1 Optical port
1 Coaxial port
1 Audio IN L/R
1 USB port
Samsung LCD TV :
1 Optical port
Thanks in advance.
Nair
