one good entry level jxd tab
kaushik
There are number of good tabs in less now a days
i just had hands on with jxd s6600.It was bought by my office buddy.
price:some 3.4k
HighLights:
CPU: All Winner A13 Cortex A8 1.0GHz
GPU: Mali 400
OS: Google Android 4.0.4
RAM: 512MB DDR3
Internal storage capacity: 8GB
External storage: Micro SD card (up to 32GB) - not included
Screen: 7 inch 16:9 TFT LCD capacitive multi-touch panel 800 x 480 (WVGA)
Front camera: 0.3 Megapixel
Flash: Flash 11.0
Support Video Calls Online
What i liked:
as a tab first things i check are touch , video and battery life.
touch response is better than Samsung Gtab1.
most vids played very smooth incl full hd, due to dedicated gpu unit.
battery life:is justt cooool,it drained 7% after 4 hours!! on standby .
with video will go 6hour .
owner tested with pen drive/wifi etc it was good.
finally build quality: jxd is good at nice finish and wellfit cases as always
TBD: using as source to dac
the gadget is giving ,very good standby life after 30hours drainage is 17%.
shop was Dinodirect dot com.
further played with it :
USB audio: not yet...Grrr :(,after the new updates on OS it will be done,the port is OTG and supports
most devices..
One good part is most 3gmodems are already supported
wireless mouse: Damn good ,out of no where cursor pops in and does all like pc
so will be very good with wireless kb too
One good bedside e-reader for sure,the Tabbie is slim with thin edges tried FBReader app works fine,pdf,epub etc all good.
slide finger on left margin the light dims or goes full
some bike game i tried,the tilt sensor is good,
Sensitive 5point finger sensing for games like fruit ninja.
ok thanks , i saw one site selling it for 61 dollars but no free shipping .
a few questions :)
can you tell me about the screen of this tab ? is it 16 million colors like samsung ace ?
and can we trust this site ?
they ship the item as registered parcel or normal parcel ?
may be u refer the site ..
china shipping is good..ask vendor for more.
Infact u can tk indian tabs with A13 processsors
but make sure u get same specs like capacitive screen/3000mAH battery
i checked the site and others .
but they dont mention the colors of screen . so yes .. its better to ask them . thx :)
