I posted the same query in my intro.. but since it does not proper tag, i thought i will post in new thread as i am desperately waiting for suggestions.
I have purchased Onkyo HTS3300 from Bajaj Electronic Punjagutta in July 2010. After lots of auditions,online research( i should sincerely thank hifivision and its members) i found this one which fitted exactly into my budget 25K. (i bought for 23K after little koshish..). As i don't have special room for HT, I placed this setup in my hall which is 14 ft *10 ft, i fixed speakers at four corners. Also as rear speaker cable length was not sufficient, i bought local and used for them.
I have TCL DVD player, which has coaxial out and connect to coaxial in to HTS. Audio is decent when i play original DVDs (had BIGFLIX a/c for one year). I did not use HDMI, and thought sound quality will improve tremendously if i have one.
So was waiting to buy blue ray player, which will play hd format and i can enjoy real performance of Onkyo, but my friend suggested to purchase a laptop which can do that using hdmi out.
Now coming to the issues
1) When i connect mp3 player or PC / Laptop's audio out to AUX nput Line in port on front panel, audio is really really poor. I did not expect this from this Onkyo. (Please suggest any good quality cable if it helps)
2) I purchased DELL Inspiron 15R N5010, which has HDMI out, Intels HD Graphic, Intel HD audio. Even when i connect HDMI to HT, and play songs which i normally play from DVD player, audio is comparatively poor, i mean clarity wise as well as output wise. I need to increase volume to 40 to listen what i used to listen at 20 from DVD player. ( I used max vol in laptop and vlc player). I see PCM in AVR, for all HD movies i play via vlc player.
3) When i test my onboard sound cards audio (5.1) when i connect to HT from laptop using HDMI, as shown in following images, i get sound from center speaker for all the speakers. For rear, i get in front too.. some sort of mess happening.
But from Onkyo's Level calibration option, i can perfectly get o/p from respective speakers only.
There must be some issue in laptop setup. If any faced similar issue with any laptop please let me know how to resolve this.
I am extremely disappointed as i am not able to use my laptop with Onkyo HTS3300 as i desired.
I followed following link expecting wil resolve my problems, but it did not.
http://www.hifivision.com/home-theat...3300-a-36.html.
I instlled AC3 filters with suggested settings, but of no use.
Guys please help me in setting up my laptop with HTS3300.
My desire is to watch torrent downloads ( 5.1 audio format downloads) from laptop with Onkyo Surround effects.
Atleast i wish to get similar output what i get from playing original DVD movie from DVD player.
Can you guys suggest settings you are using for best performance.
Like
4. SP Config -> Cross Over frequency
7. Audio Adjust settings
-> Input MUX (Main or Sub or M/S)
-> Audyssey
-> Dynamic EQ
-> Ref Level
-> Dyn Vol
Please suggest how i can best use my Onkyo , with laptop, any standard cables (for HDMI) will bring me out of this mess? Do i need to complain to DELL if it is their issue?
Hope you guys will resolve my long standing issue..
Thanks ...
Like
-> Audyssey
-> Dynamic EQ
-> Ref Level
-> Dyn Vol
Thanks ...
