Onkyo HTs3400 or Denon or Yamaha RXV 371
ramanans_cdl
Chennai
I have a hall with 20' X 16' . I wish to have a good theatre like experience. My max budget is 25K. I have enquired an Onkyo dealer for HTs3400 @Rs24500. I'm in dilema of which combination to go far with min cost.
Onkyo HT S3400
Denon 1312
Yamaha RX V371.
or any other which you can suggest. Please advice as I can't prolong the purchase.
Thanks in advance!!!
In 25K there is only one option out of the list you mentioned - Onkyo 3400. This is a full HTIB with 5.1 speakers. The others are AVRs and you will need to buy an equally good 5.1 speaker system.
the only downside with onkyo is it doesn't support active subwoofer, so if you planning to stick to this system for like a long long time then go for it
else look for denon 1312XP package
I have just bought Onkyo HT-s3400. Bought in 5.1 Digital park, Chennai for Rs 24000/-. I have installed my self and it was good. But looks like one speaker is silent. Need to call the Onkyo installer person.
Hi can u share the dealer's contact number? Me too planned to get Onkyo 3400. And the rate u mentioned is quite low.
Also how the bass in Onkyo dude? Is it heavy?
Thats a great price, could u help us with the number of the dealer.
Need to buy one in a couple of days.
Thx n Regards
Onkyo HT-S3400 has been discontinued and replaced with HT-S3500 which is now available. Suggest to go with HT-S3500. Denon 1312XP might stretch your budget a bit more than 25k but comes with an active subwoofer. If possible demo both the systems and then decide.
