sapphire903
HI Friends,
I had bought Onkyo S3400 during the first half of 2011 and I used it for about two years, then I came to the US and it was unused for about 3 years, now I have it with me again in the US with a step up transformer.
It turns on perfectly fine, also plays sound as passthrough - either HDMI or Audio Out using Composite AV cable to TV - but if I try to use the receiver, it is not sending any sound to any of the speakers - to keep it simple I was just testing AM/FM signals - it was working fine with audio out to TV but as soon as I took the connection off, the sound went blank.
I have checked everything, all the setting seems to be fine, infact they were exactly the way I had left - I tried resetting the settings also.
I have seen some videos on Onkyo receivers having problems with HDMI board/DTS chip with soldering issues and so on and people are fixing with Heat Guns / Heat Sinks - I am not sure if HT-R390 would have the same issue?
Are there any troubleshooting steps that I should try ? Any help that will be greatly appreciated or me being in the US - I would just have to use that as a 25000 RS paperweight !
Thank you folks...
Thank you folks...
