Onkyo tx-8511 as power amp with NAD 326bee? will it work
santosh4
Friends,
I am confused and need your advice, for a perfect stero setup l repeat STEREO
What I have as of now:
1. PSB T5 - 200wats
2. Onkyo - TX-8511
3. Pioneer BDP 440 - Bluray player
4. Wharfedale subwoofer sw150
Thinking to Upgrade:
NAD 326BEE as pre-amp and use onkyo as power amp and connect swbwoofer to subwoofer out of NAD 326BEE.
Question: Will using Onkyo as power amp degrades the sound quality of NAD? or Just Use only NAD 326BEE as my room size is 13*9 feet? and sell off onkyo 8511?
sir, instead of using integrated as pre , use a dedicated pre amp. (for that budget look in to used amp section)
dedicated pre always wins:)
amp signature sound largely depends on preamp section hence i think onkyo as a power amp will not affect the sound
Friends,
1. PSB T5 - 200wats
2. Onkyo - TX-8511
To use your Onkyo as power-amp with any Pre-amp, it must have Pre-in & Pre-out connection usually connected by jumpers..
I think Onkyo TX 8511 can't be used as a power-amp... You already have a stereo amplifier, why get an other one... Instead add a Good DAC which will improve your experience....
Finally got 375BEE and now with PSB T5 its lovely but belive me the warfedale connected to speaker B on Nad 375bee has filled up the missing Thump with smooth bass... really loving it.
attached Pioneer BDP-440 now wondering should I go for external DAC to play DSD or just go with WMV format.
Challenge I am facing now :
1. 375bee has a optional USB DAC(MDAC Dac2) that can be attached , should I go for it?
2. is there any way to play DSD files on my Pioneer BDP-440?
3.Does Pioneer BDP-440 support 24bit/192khz on USB if so what format (wav? or wma? or what) since it DOES NOT SUPPORT FLAC :-(
