Onkyo TX-NR609: No DTS-MA or Dolby TrueHD
Imtiaz
Oman
Hi there,
I have an Onkyo TX-NR609 and a Panasonic DMP-BDT310 blu-ray player. Everything worked fine. I moved home and appear to have changed something accidentally. Dolby TrueHD Blu-ray disc plays as Dolby D and DTS-Master Audio as DTS. Tried playing different disc's. Same result. Not sure the setting on the blu-ray player is incorrect or the Onkyo receiver. Please help anyone. Thanks
Is it possible that you switched HDMI cable / ports?
Also make sure that all speakers are wired properly and recognised in the AVR
If u have connected via optical /coaxial or HDMI arc (not eARC) then obviously you wont get anything higher than basic DTS and Dolby
If you have connected player separately via HDMI then just check player settings if its limiting the full bandwidth of HDMA and TrueHD before it reaches the receiver
