Online UPS for HT setup
dpkprabhakaran
Chennai
Hi All,
I am currently facing voltage issue at my home.
Planning to go for the below online ups. Any real world reviews would be helpful.
Equipment to be connected to UPS
Denon 3800H , Polk HTS 10 Sup woofer, 55 in Samsung TV and Nvidia Shield TV Pro.
Product Link:
Microtek DSP Motors Online UPS MAX-3KVA 72V Sinewave with in-Built Batteries (12V 7AHx6),Black https://amzn.eu/d/3gmk1LN
Thanks,
Deepak Prabhakaran
Hi All,
Product Link:
Thanks,
Deepak Prabhakaran
What exactly are you looking for as inputs , I use an Eaton 3KVA Online UPS and my primary use case was to avoid abrupt shutdowns of the system during power cut primarily and of course the surge protection it offered.
It does it's job perfectly well of maintaining a stable voltage and have not faced any surge related issues either till date. The model I purchased doesn't make a lot of noise ( fan running noise) and is quiet sleek , despite that have kept it near the mains and not in my audio room. The noise is an important aspect if you plan on keeping it in your HT room, personally I would recommend having your entire HT room line on the ups via the mains.
Hi Flux,
Microtek was the cheapest online ups i could find.
Just wanted to get real world reviews before buying
Deepak Prabhakaran
+1 for Eaton 3KVA which I'm using too in my setup. If you're interested, message me and I can share the contact of Eaton distributor number.
Hi @ktks1 , @fLUX could you please suggest as what is the recommended model to be used with the HT appliances and OLED TV. Recently I got in touch with one of the Eaton distributors in Bangalore and he is recommending me to go ahead with Eaton 9PX. Please advise...
